window patterns
Discussion in 'General Critical Analysis' started by skieur, Nov 30, 2007.
  1. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    The building said 1890 on the front and the design, particularly the windows caught my eye.
    skieur
    [​IMG]
  2. midnitejam
    midnitejam TPF Noob!
    Mar 26, 2004
    314
    Ohio
    It's under exposed. The light pole is distracting
  3. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    The image itself was not underexposed or the images in the windows would have been dark and that it not the case. Nevertheless selective brightening was indeed a worthwhile approach and taking out the light standard although not easy was also appropriate too.
    Thank you for your suggestions.
    skieur
    [​IMG]
  4. New England Moments
    New England Moments TPF Noob!
    May 13, 2007
    453
    Vermont
    I like the Re do on this Much Better!! Nice Clone Job on the light, but removing the background bldg. really put it into perspective... a bit more cloning than I would want to take on , and sure after involved , you must have felt the same way..
    This would probably be next to impossible to get any straighter I suppose.. but it still has that tilt feel to the left... Think it was because the Orig, shot was not taken dead on , at same level or plane of height as subject.. more or less meaning , you were shooting up some..and really not dead on straight..
    The window glass in your orig. seems to be better controlled as far as glare or flare... must be the extra enlarging in second shot changed the previous work ??
    but overall , I like what you have here, very interesting shot !! great Patterns !
  5. Paolo Duzioni
    Paolo Duzioni TPF Noob!
    Nov 18, 2007
    26
    Bergamo, ITALY
    Nice re-do. I would like to shot a soft HDR on this subject. Anyway, except the overall tilting, i LIKE this shot!
  6. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    Thanks for the comments, New England and Paolo. The problem with the allignment was that the building was not square but rather in a slight arc with the edges closer to the camera than the centre. Shooting with a 28 mm from a lower angle compounded the problem. I tried some straightening and lens distortion correction but still have not gotten the results that I want as yet.
    By the way, this looks nothing like the original below:
    skieur
    [​IMG]
