A tree
The tree, in my opinion, is a bit unsightly and static. A landscape shot would be better if you can put the tree about a third the way from the right with the lake, or mountain, on the left.
This tree is an interesting subject and you did a good job isolating it considering the surroundings.
I don't know why, but in this picture and some of your other pictures there is lots of noise. Color noise, artifacting, and such that diminishes the quality of the image. What is causing that?
Also, saturation from the sky seems to bleed into the leaves.
Are you oversharpening your photos? Or do you use the sharpening tool at all? Just a guess to Rotanimod's Question about the noise.
Or have the tree loom over the lake. The mountains behind the tree is a bit distracting.
A nice shot, 'though it seems to have a bit of a downhill lean to the right...
Thank you sir...when the border of the lake is uneven, i find some difficulty in deciding the inclination :grumpy:
Regards :D
Thank you Fb; i too had the thought of tree being towards the center of the frame; but its branch is too much towards the right; so i could not move it more in that direction.
Thank you :D
Thank you Majeed; all the problems you mentioned has a single answer; I am very bad in post processing; must learn more ;)
Actually the atmosphere was foggy; my brightening, boosting of contrast and sharpening spoilt the image to the extent you see here :blushing:
Thank you :D
What can i do about this, FB? :scratch:
Thank you :D
OK, I am posting another one without tree....
Did not do any adjustment on colors :D
Regards :D
