Access computer from home to comouter at work remotely question.
annamaria
Milledgeville, GA
I am going to install Team Viewer or other free similar software on the computer at home and on the computer at work so I can access the files, do transfers and other tasks. This may sound silly, but does the computer at work need to be on for me to access it from home? Typo on the title sorry.
yes, it needs to be on
FWIW, I tried TeamViewer when LogMeIn went commercial. Since TeamViewer is free only for non-commercial use, and since my work PC is connected to an AD domain, it wouldn't work as a "free" install. I contacted help about this, and they were able to set my account to free after I explained that I was using it only for non-commercial purposes, but I figured I was close enough to a gray area to look at other solutions. In the end, I wound up opening ports on my firewall to connect Remote Desktop to my home PC from my work PC.
In any event, keep an eye open for that if you use TeamViewer.
FWIW, I tried TeamViewer when LogMeIn went commercial. Since TeamViewer is free only for non-commercial use, and since my work PC is connected to an AD domain, it wouldn't work as a "free" install. I contacted help about this, and they were able to set my account to free after I explained that I was using it only for non-commercial purposes, but I figured I was close enough to a gray area to look at other solutions. In the end, I wound up opening ports on my firewall to connect Remote Desktop to my home PC from my work PC. In any event, keep an eye open for that if you use TeamViewer.
Thanks for letting me know. I work for a small private Christian school and would only be using it to do some work from home nothing commercial. I wish that there was a software that I could turn the computer on and off from home since I will not be there as much in the summer.
Why not just use dropbox to sync the files back and forth?
I could but I also wanted to be able to create open office docs from home.
You can't create files at home?
Yes I can just did not want to fool with transferring it to Dropbox, email or usb flash drive. Also I have lots of files at the school's computer that I sometimes have to edit, etc.
You should check with your IT department and make sure they're ok with you doing that. As an IT person, I grind my teeth when I see things like this.
There may also be a perfectly good way for you to get to the machine without third party software. VPN in (if you have a VPN) and then RDP to the desktop.
Apperintly you don't understand how dropbox works. When you install it and sign in it crests a Dropbox folder on your computer. ANY file you save in that folder is automatically synced with Dropbox. All you have to do after you install it on your work computer is move all those files into the Dropbox folder and save new files to the Dropbox folder. Dropbox will keep them synced between the computers, NO NEED FOR TRANSFERRING FILES.
Apperintly you don't understand how dropbox works. When you install it and sign in it crests a Dropbox folder on your computer. ANY file you save in that folder is automatically synced with Dropbox. All you have to do after you install it on your work computer is move all those files into the Dropbox folder and save new files to the Dropbox folder. Dropbox will keep them synced between the computers, NO NEED FOR TRANSFERRING FILES. Video Link: http://youtu.be/OFb0NaeRmdg
Thanks for the info, I will give it a try. Oh and thanks for the video too :-)
Once you save a file to the Dropbox folder, it will be on their servers. Then you merely open it from any computer, work on it, and click "Save". It will save the updated file to Dropbox automatically.
