Access computer from home to comouter at work remotely question.
Yup, and there's also google drive, Microsoft OneDrive, and a number of others. I use OneDrive, personally, because it also syncs up my OneNote notebooks.
I am going to install Team Viewer or other free similar software on the computer at home and on the computer at work so I can access the files, do transfers and other tasks. This may sound silly, but does the computer at work need to be on for me to access it from home? Typo on the title sorry.
It only needs to be on during your session: if the motherboard supports 'Wake On LAN' then you may send it to power down when not in use.
Once you save a file to the Dropbox folder, it will be on their servers. Then you merely open it from any computer, work on it, and click "Save". It will save the updated file to Dropbox automatically.
Sounds great! Thanks for the explanation and help :-)
Thanks manaheim I will look into those you mentioned as well.
Thanks ar76 for the info and link I will look into it, though I don't know if the motherboard supports it.
You should check with your IT department and make sure they're ok with you doing that. As an IT person, I grind my teeth when I see things like this. There may also be a perfectly good way for you to get to the machine without third party software. VPN in (if you have a VPN) and then RDP to the desktop.
Don't know much about VPN, though I have heard of it. Will have to read up on it
Before you do anything contact your IT person/section about what you are wanting to do. You are potentially creating a hole that the properly educated people could drive a moving van through leaving or picking up what ever they want.
Thanks for the warning I appreciate it.
LogMeIn and GoSupportNow are two tools similar to TeamViewer that could solve your problem. Both tools are paid products.
