Aperture Cropping
quinte
Arkansas
I use Apple's Aperture 3 a great deal. Often when I have prints larger than 4x6 made, the cropping in the print does not match the photo in digital form. Most of the time something gets cut off in the print. Tips on how to conquer this issue??
Well, think about it. A 4x6 print isn't the same shape/ratio as a 5x7 print. Neither is it the same shape as an 8x10 print.
So if you order one of those other sizes, the shape (aspect ratio) will not match the 4x6 shape (2:3) ratio. So the result is that your photo has to be cropped. (the alternative would be to squish your image to fit the new size, but nobody wants that :lol:
So before you order one of those other sizes, crop the image yourself to the proper shape/aspect ratio. That way, you can decide what gets cut off and what doesn't.
If you don't like your options for how to crop, then choose a size that does match your pictures size. So rather than an 8x10, you could print an 8x12...and so on.
Also, experienced photographers will often shoot 'loose', giving themselves room in the photo, so that they can easily crop when needed.
Thanks Big Mike. I had actually figured it out after my post. Sent a pic off for printing, and it was as I had cropped. Thanks for you time and advice.
