photocist
- Joined
- Oct 21, 2010
- Messages
- 605
- Reaction score
- 57
- Location
- Oakland, CA
- Can others edit my Photos
- Photos OK to edit
I would be wary of this.One problem with that high of a aperture is you start to lose sharpness to diffraction. For landscapes, use hyperfocal- google it.
Hyperfocal is really just a wide DOF that is set so that the far side of the field is at infinity. While this obviously can be used effectively, it is not necessary. Like "TheBiles" said, f/16 or f/22 is usually used for landscapes. For low quality glass (and even high quality glass to some degree), f/22 WILL make an image OVERALL less sharp, but the DOF will be what is required. When shooting with my manual medium format camera, I almost always have it at f/16, and f/22 if I really need a large DOF.
For landscapes, generally you will want f/16 or above, unless everything you are shooting at is at the infinity for the lens, in which case f/11 is probably ok. It is a photo by photo basis, and the more you use it the more you will feel comfortable adjusting to what you want.
