Buckster said:
UV filters are trash as well these days. They don't do anything for digital shooters except lower image quality somewhat. And no, they don't protect your lens.
I thought that a UV Filter would protect the front of the lens from scratches.
Not in my experience. If you're doing things that might scratch the front element of your hundreds or thousands of dollars lenses, you've got other issues you need to work out. Lens caps and pouches and holsters keep them safe when they're not being used, and hoods and care keep them safe when you're looking through them and shooting photos.
In all honesty, I rarely ever even have lens caps on any of my lenses. I do use holsters and cases made to store them whenever I'm not actually shooting, for the most part, but when I want to shoot, I want that lens available RIGHT NOW, as soon as I pull it out, and I always have a camera ready at arm's length without a lens cap on - ALWAYS, even when I'm driving.
Other than the holsters and cases, I'm also not particularly careful with my gear either, tbh. They're tools to me, and when I'm using them, they are getting USED. I'm into making photos, not protecting an "investment". When that means getting down and dirtly, so be it. Not that I would point them into the wind during a sand storm, but I've spent a lot of time on beaches and deserts and every other kind of environment with them, and haven't had a problem yet.
And after all that, I still don't have scratches or gouges or problems with my lenses. First of all, they're tougher than a lot of people give them credit for. This glass ain't like the thin, easily breakable stuff in your windows (or in a UV filter). Second of all, minor scratches don't really mean much to image quality anyway, believe it or not. Check this out:
Dirty lens article
On the other hand, I've used UV filters, starting about 40 years ago, when they were pretty much necessary for film shooting (where using them came from). They've always had a few problems associated with them when it comes to image quality, because they set up reflections and flare and other strange moire type image quality problems with the lenses they're on. Digital sensors have UV protection built right onto them, so you don't need it for that anymore, and the rest of the problems mentioned above go away when you remove that unnecessary filter.
The idea that they're useful to protect your lens is a marketing gimmick to try to sell you the filters when you buy your gear, because there's a huge markup on them and they're trying to sell you as much stuff as they can while you've got your wallet open to them. Lots of folks buying gear simply don't know any better, so it sounds good to them, and those additional relatively few dollars, compared to the several hundred or even thousands they're spending already, seems like a worthy drop in the bucket for the "protection" the sales team will tell you it provides. And though some people will hang on to that sales advice like it's gospel for the rest of their lives, ignoring the image quality issues of putting a cheap piece of glass in front of one they paid many hundreds or even thousands for and proclaiming they don't see any such IQ problems, it's just not true.
I have an ND8 filter and a polariser filter, what others would you recommend, if any ?
None, until you have an actual need for either more or less stops in an ND filter - then fulfill that need.
Also, would you suggest Cokin square type or the standard round type that screw to the end of a lens ?
I like and use both when it comes to polarizers. For Cokin, it's still a round polarizer, but fits into their square holder which makes it easy to place and remove, which is the beauty of the square systems like Cokin, Lee or others. For ND's all I've ever used are the square filters, and I like them just fine. Fair warning on the less expensive Cokin ND filters: They have a bit of a magenta cast to them, so you'll want to work out a way to deal with white balance on them. I use a collapsible gray card/target to deal with white balance issues.
