autocad 2013 error
jacobsaunier
While recently working on a .dwg on my autocad mep 2013 I got a fatal error message: Unhandled access violation reading 0x0010 exception at ec45af2dh and now it does this every time I try to open the program how can I fix this.
Unistall, clean the registry, reinstall. If you have never done this get someone that is comfortable working with the registry to clean all the traces of the program.
You might try the support section for the company that wrote the program to see if they have clean uninstall instructions.
I use Autocad but sadly i cannot address this particular error message. I'm actually overall happy I have not seen it.
Your best bet would be to dry an Autocad/drafting forum.
Are there WET Autocad/drafting forums???:allteeth:
:irked: One little typo and everyone's a smart-@$$~
Damn straight. Just because you are a mod does not exempt you from a little smart-@$$ery. :allteeth:
Besides your from Canada, how are we to know whether you have wet Autocad forums or not? Besides you live in a country that has no space program yet you built a SPACE NEEDLE!:biglaugh:
We do so have a space program...The Canadian Space Agency. We're all very proud of the Canadarm on the space shuttle.
That IS our space program! :P
As well you should. :icon_thumleft:
That IS our space program! :p
You can't fool us, All of us here in the good ol'e USofA know that it is really a secret military instillation with the intent of attacking the USA. As proof I offer: Canadian Bacon 1995 - IMDb
:biglaugh:
Doesn't matter which side of the border you are on, that is funny movie.
Couple helpful resources to get more knowledge about alternative ways of solution Recovery Toolbox for DWG
Use the auto save files to recover your work:
1. Go to Tools --> Options
2. Inside Options go to the “Files” Tab (far left)
3. Inside the files tab go to: “Automatic Save File Location” and see where the autosave files are stored. (mine where stored at C:\Documents and Settings\USERNAME\Local Settings\Temp)
4. Then access that folder and try to find a file with the same file name but different extension. (The auto save files should have a either a .BAK or a .SV$ extension) (if you can’t see the folder, you need to go to Tools --> folder Options --> View --> and Make sure "show hidden files and folders" is SELECTED) .
5. Check the "date modified" of those files, if the date and time makes sense according to when you had the last file crashes, there is a good chance that those files contain the information you need, so there is no need to redraw everything.
6. Change the file extension of the file you think it might be the good one from .bak or .sv$ to .dwg (to be able to change the file extension you need to be able to see it. To do that, on any folder go to Tools --> Folder Options --> View --> and make sure that "Hide extensions for known file types" is UNCHECKED)
If your auto-save feature is disabled, you can enable it in AutoCAD by going to Tools --> Options --> "Open and Save" Tab --> and there make sure that the "Automatic save" on the lower left corner is active and preferably set to every 10 minutes or less. To easily change the time of the auto save feature, use the SAVETIME system variable
I never got those kinds of errors with a T-square, triangles and compass. :biglaugh:
On another note: shouldn't this be put into one of the non-photo areas?
