Going. The composition is fine, the conversion is ok.
Because of the focal point distance and 50 mm focal length, a well blurred background was apparently out of the question, so f/1.4 was not really needed.
Wide open most prime lenses have diminished focus sharpness. Using at least one stop less of aperture (f/2) would have helped the sharpness while still letting you use 1/250 for the shutter speed, and the DOF would not have changed appreciably.
You could have reduced the lens aperture another stop, to f/2.8, and gained some more focus sharpness. By changing the ISO to ISO 200 you could still have used 1/250 as the shutter speed.
Since the main motion in the photo is perpendicular to the plane of the image sensor, less shutter speed is needed to stop motion than if the motion were parallel to the plane of the image sensor.
I recommend a square crop, and a little cloning work to remove the other people from the photo:
