MTVision
- Joined
- Aug 1, 2011
- Messages
- 3,008
- Reaction score
- 527
- Location
- Vermont, US
- Can others edit my Photos
- Photos OK to edit
jwbryson1 said:In Undestanding Exposure, I believe what Bryan Peterson means is to point at the sky with the camera in manual mode and take a meter reading off of the sky. By pressing 1/2 way on the shutter release button you'll be able to get a meter reading by looking at the camera settings and where the needle is pointing. You do not need to be in focus to get a proper meter reading. By recomposing, it is my understanding that you would then turn the camera back to the subject you wish to photograph and while still in manual mode, adjust your settings to the same readings that you found when you metered off of the sky. You would not move the camera while holding down the shutter release button. You would instead check the meter reading off of the sky, memorize it, remove your finger from the shutter button and point back at your subject. Then make sure that in manual mode you adjust the settings to the reading you just memorized and then you'd take the photo.
Somebody please correct me if I'm wrong.
Adjust the settings while pointing camera at the sky. There is no point in memorizing the settings - just more work. With the shutter press halfway and pointing at sky adjust the aperture, shutter speed, iso until you reach a correct exposure. Release shutter. Then move camera, focus On subject and take the picture.
Metering of the sky is similar to recomposing I guess. Recomposing is when, for example, taking a picture of a person. Focus on persons eye with center focus point. Lock focus then adjust the camera so the person is in a different part of the frame - to the far left/right.
