investmenttechnology
- Joined
- Aug 15, 2011
- Messages
- 107
- Reaction score
- 2
- Location
- Australia
- Can others edit my Photos
- Photos OK to edit
hey guys, I have been looking for my first tripod for the past few days or so, and when down to my local Benro distributor and had a feel at the Benro range. After playing around, I definitely wanted the carbon fibre and twist lock, and after taking into my height (175cm) and future photographic needs (will be getting more lens in the future), I have decided to go with size 2 (max load of 12kg) or size 3 (max load of 18kg).
so basically I have decided on two particular models, the C2970T and the C3580T.
The C2970T has 3 sections, normal height of 142cm/max height of 169cm and max load of 12kg, the centre column can be turned horizontally.
The C3580T has 4 sections, normal height of 160cm/max height of 187cm and max load of 18kg, the centre column can not be turned horizontally.
Without taking price as a factor, is horizontal centre column of the C2970T worth giving up the extra height, load capacity and sturdiness of the larger C3580T?
And also, I can just get a Manfrotto lateral arm for the C3580T and basically adds the horizontal function, which mean their is no point in getting the C2970T?
