Besiege the Walls: A few questions from a curious photographer?
King Panda
A Few Questions:
I have a Macbook Pro and I was messing around with the system preferences until I scrolled over the Display option and opened the Color tab. I was wondering what would be the ideal Display Profile to use for graphic design with Photoshop?
Secondly, I took a solid shot sequence and was wondering what would be the best way to display them. Side-by-side or span them out in four corners of the page? Or some sort of alternate method that I cannot conjure right now because I am lacking too much sleep.
Far from the point, my last question is, when merging images to create a panoramic image, would it be best if I went through the images and merged them side by side by transforming the tilt on the faulty unaligned ones then attempt to smoothen the transition? Does anyone know of a Panoramic merge technique that works well in PS?
Cheers!
PS has the photomerge module.
Never used it though.
What version of PS I use photomerge in CS3 and it is amazing much faster and more acurat than with CS2. That ands the B&W conversion is the only reason I upgraded to CS3. There is usualy very little editing needed after photomerge CS3 if the pics are shot well in the first place.
