Brown Hair Looks Purple
I see purple-ish tints... or Blue... in the shiny area of the hair. Is that what your referring to?
Needs some warming. Her hair has a slight tint, as well as the white stripes on her shirt appear blue-ish.
It thought it might help if I uploaded another one that is more obvious so here are a couple more examples:
http://img813.imageshack.us/img813/319/img3800.jpg
http://img46.imageshack.us/img46/936/img3723e.jpg
I'm not the best yet at having the image perfectly color balanced but when I play with warming it and making other adjustments the purple stays. And some of the hair looks just right so when I make adjustments for the purple then their real color of their hair starts to look weird.
Both of these shots are pretty blue... warm them up and I bet it'll move toward brown.
Yet again, same issue. You'll also get more feedback if you post the pictures themselves in your posts. :)
Here's one of the pictures warmed up and to me the purple coloring in her hair is worse. In reality her hair is brown/black.
http://img708.imageshack.us/img708/2662/img3723warm.jpg
Surely there's something wrong with images coming straight out of the camera with purple hair??? Is there something wrong with how I'm shooting or processing the raw image?
The slight blue cast is because you only used window light. Since the sky is blue, light from it has a blue cast.
Had you used flash as the dominant light source, the slight blue cast would have been overwhemed and not visible.
Part of the issue is underexposure of the hair.
I do see that in the shot above, the mother's hair has a slight "warm" color bias to it--her shirt is BLACK, clearly BLACK...but her hair is not. One possible issue could be if she is coloring her hair...also, quite a few digital sensors exhibit a slight to a great deal of sensitivity to near-UV light waves...the Nikon D2h was a bad example...it rendered all sorts of normally "black" objects as a purple-ish black-ish color, much like the woman's hair.
In a situation like this, with a lot of the light coming from an open sky, it is interesting to note that the woman's hair is NOT 100 percent black, bu her shirt is rendered as black...so...it's not that the camera is incapable of rendering a black-black...
The Leica M-8 also suffered terribly from the same issue as the Nikon D2h, rendering myriad "black" objects with this odd, purple-ish/blackish coloration.
the same thing hapens to me, only on a much more drastic scale. it's only in some lighting but I don't know why. here is a link: Facebook
Your first example used Auto WB, the second two Manual WB. What did you set the WB for in manual?
