Bullets
SensePhoto
USA, PA
Messing around with a home made lightbox
very nice i like it, it would've looked even better if there werent any shadows. but nice. may i ask what lighting equipment you'r using?
thank you. All i use is two table lamps reflecting of two white pieces of cardboard, its very primitive but im still working on it. Low iso and slow shutter helps out too.
Watch your control of your light. You have shadow areas too dark like the cigar box and you have blown highlights like the watch band.
I liked the first one very much; second one is also sounds nice :)
But third one is a bit spoilt....lower part of strap has burned and fused with the white of back ground; glare on glass is also troubling :grumpy:
Regards :D
To avoid shadows, go to a photographic supply store and pick up a reflective dome. You put small objects on the light table and shoot through the top of the reflective dome.
skieur
