C&C to brighten this a little please!
What do you have, or are you using, as an image editor. If you tell us that, then someone will probably be able to help you.
Cheers,
WesternGuy
With regards to brightening this photo just a little, you need to be careful you don't brighten ALL of it, as parts of the sky are correctly exposed, throwing the rest into underexposure. So in post you want to make sure you only brighten up those parts and leave the bright parts of the sky as they are, since everything else will make them too bright. Which means you need a programme that offers you the opportunity to mask off those parts of your picture that you don't want to touch, only brightening what you really want to. See what I mean?
I feel this is a photo worth the while you'll have to spend on it in post.
I have CS5 but do not really know how to use it yet! I just wanted to lighten the rocks at the bottom - maybe be better to crop them out?
Thank you LaFoto - value your advice!
Like this?
Wow thank you - I really need to take some lessons in Photoshop!!
I used lightroom mostly to brighten this. Maybe it's a bit too bright but just to show you what software can do...
