Sorry, that was a typo on my part: the 300 and 400 are the f/2.8 VR models, the 500 and 600mm models are the f/4 VR models; the reason you have probably seen 500 and 600 lenses referenced as f/2.8 is that MOST people group the super-telephotos as 300/400/500/600 and in 10 years you've probably seen that many people make typos...and you're just the kind of guy who probably keeps track of such mistakes.
Nikon has updated its super-telephotos as a "set" for many decades now; like the Ai series, then the Ai-S series, then the AF versions, then the AF-i models with the first in-lens AF motors, then the AF-S models, and now, finally, the super-telephoto lineup is is ALL unified with AF-S G VR mounts;200-400 f/4 zoom, 200 f/2, 300/f2.8, 400/f2.8, 500 f/4, 600/f4, and all designated as AF-S G, with Vibration Reduction across all six lenses. NO f/stop ring on any of them.
As for your comment, "You're backwards. Lower megapixels at high ISO = less noise. One of the reasons the 1D Mark III is 10mp. Also the reason why D3, D700, D300s and D90 all remained 12.1 and 12.3 mp."
Well, that's a common theory that doesn't take into account advances in microlens design and image processing hardware and software; the original Nikon D1 and D1h models both had a 2.7 MP sensor, but it later became possible to get to 12 MP with LESS noise and higher resolving power. Also, noise tends to be sublimated when printing, and the higher-MP cameras also produce VASTLY larger images; today's upcoming 18 MP Canon 7D has a BIG image that measures 5,184-pixels on the long axis,while a 2.7 MP D1h produced a 2,008 pixel image on the long axis; if one takes the image from the new, ultra-high MP 7D and down-sizes it to match the size of the image from the 2.7 MP D1h image, or a 1D 4.2 MP image, or an EOS 30D 8.2 MP image, the actual, visible noise in a PRINT from the 18MP camera's file will be visibly better,and more pleasing, than the noise level from a camera that has a lower MP count but much older technology.
If one pixel-peeps and looks at huge,high MP images on-screen, yes there is noise, but there is also more real,actual resolved detail,and if one actually makes prints, or down-samples the images, the noise with high-MP sensors is pretty bearable.
Improvements in the image processing can make a high-MP sensor look good,or great. The sensel (sic) shared by the Sony a900 and the Nikon D3x is the same sensel, but Nikon's additions to the sensel and their proprietary image processing hardware and software yields images with lower noise and better image quality than the Sony camera yields. The 1D Mark III's 10.3 MP APS-H sensor is a very good sensor, and it yields a nice file,perfectly adequate when the camera can manage to focus properly. But the reason it's 10.3 MP is that newpaper and magazine screen printing makes higher MP counts prety much useless--the halftone screens used in today's magazines cut in-camera resolution so much that I'd challenge anybody to go through back issues of Sports Illustated and look at the double truck that were shot with the 4.2 MP 1D or the 8.2 MP 1D Mark II or the 1D Mark II, or the increasingly numerous Nikon D3 spreads--newspaper and magazine halftone reproduction makes it virtually impossible to tell if the capture file was 4,6,8,10,or 12 megapixels. Even on a two-page spread in Spots Illustrated.
As a former newspaper shooter, I'm familiar with prepping and transmitting images for halftone reproduction; the 2.7 MP of the D1h was quite adequate,and halftoned, one can barely tell the difference between 2.7 and 12.2 MP captures. A 10 MP file transmits via FTP a LOT faster than a 24.6 MP file,and the halftone issue and the transmission via e-mail or FTP is the reason PJ/sports cameras range from 10 to 12.2 MP. Many sports guys shoot 700 to 1,000 frames at a football or baseball game, and a smaller file size helps with card swaps, editing,archiving, and transmitting and until Nikon invented 4-channel readout, smaller MP count sensors helped with image buffer AND card write speeds, leading to higher Frames Per Second rates on sports cameras. Getting 10 FPS at 10.2 MP was about all Canon could muster in terms of throughput off the card with adequate buffer for long sequences when they engineered the 1D Mark III to run at 10 fps.
The 1D Mark III also has a very good per-pixel level image quality. Great microlens array ,perfect AA-filter, big pixels wells for high sensitivity and resistance to overexposure,and a file that writes and flushes and transmits perfectly well for newspaper, or PJ uses. 10.3 MP is a perfect compromise.
If anybody needs a high-resolution camera, Canon is over 21 MP, Nikon and Sony at 24.6 MP. The 5D Mark II at 21.7 MP shoots a better file at 3200 than the original 5D at 12.8 MP did.
