Canon 100mm 2.8 or Tamron 28-75mm 2.8
sood1992
India
I'm stuck between the two, I shoot concerts, portraits, weddings etc. Which one do you think I should get?
The zoom for flexibility
The zoom.
However that lens is not sharp until F4. It also does ok with macro so works for ring shots.
Pick up a 50 1.8 for lower light opportunities.
The Tammy is a very good lens, I have a couple, the 17-50 2.8 is also a thought, might fit in with your needs. has some with to it but not much reach for portraits. the 28-75 2.8 is great for portraits. It is a give and take there.
go with the Tamron. If you take the 100mm to a concert you will likely realise you will need to move around alot, but that likely wont be an option.
