Canon CP-E2 Flash battery pack
TwiceTown
Los Angeles, Calif.
This is an OEM flash pack that's compatible with Canon flashes that have external battery capability. It will speed up your flash recycle times and give you a lot more run time. Sure, there are tons of cheap Chinese made battery packs out there but would you really trust your $450 580ex to one of those? This is pretty much the same as the CP-E3 and CP-E4 except that it only has a 6 battery capability, which means that this one doesn't recycle as fast or last as long but is a little more compact. It also doesn't have the slide in tray, which is why I purchased a couple of CP-E4s, hence the sale. But those are a lot more pricey than this.
Sold!
