This is Canon IXUS 400 camera for IR Infrared photograph only. 680nm It has 1/1.8 large CCD , easy to setting manual white balance; metal shell, hard and durable.
The camera can take IR photo when set e-dail at M mode. These camera have been internally modified to take only infrared images. This modification allows you to shoot handheld with normal shutter speeds.
If you use this camera indoors the results will vary depending on the lighting source, as not all indoor lights give off IR light. Camera body, Compatible Battery, Compatible Charger ( travel charger , not original ) 512 MB CF Card
£100 ono
Sent Via iPhone
£100 ono
Sent Via iPhone
