Canon T3, Nikon D5000, or Nikon D3100? Please help me !!
Drumbum27
WV
What is the best dslr camera out of these three Canon T3, Nikon D5000, or Nikon D3100? I know the D3100 and T3 are newer, but I've been told the D5000 has more options then the rest of them. Which would be best for a new photographer? I know the Canon has autofocus motor, but I was told the D5000 has the sensor of the D90 making it better for picture quality. I did consider the 5100 but the price tag is a little more then I was looking for which is why I did not include it. The same goes for the T2i/T3i. I have around a $650 budget which heavily limits the options and I need a camera tomorrow so any advice helps. Thank you all in advance !!
Someone asked this last month, so here is what I said to them then:
"This question gets asked a lot (not these 2 models specifically, but essentially canon vs. nikon at entry level price point). My response is always that ergonomics is most important at this level, and that comes down purely to personal preference. Best thing to do is go to a shop and play with both models, and then buy the one that feels comfortable, and makes the most sense to you. Canon and Nikon each have slight advantages over each other in very specific areas... but I think these advantages are only important once you're at the high end and really pushing your gear to the limit. At that point it's worth choosing the technology best suited to your type of photography. At the entry level, all the offerings are so similar, that you will take the best pictures with a camera you understand and enjoy using. "
yah, i agree with analog, at the point you are at there really isn't a "better" camera so to speak. pick one up, how does it feel. look thru the viewfinder, are the buttons easy for you to navigate. find one you can sling around yer neck and take some photos and most of all, have fun with it.
I got the nikon d3100, looking back now I would have went with the d7000 or d5000 because the focus motors, and the lens are cheaper.
EDIT:
It's more expensive for the camera but lens that have the auto focus motor in them are a ton to buy, so if your camera has a motor the lens you buy in the future will be cheaper and worth it.
i would add a used D90/D80 to your research. Just for the ability to change settings with out going into the camera's menu system and AF motor, and the ability to control off camera flash.
Ok I assumed it was a motor cause when I compared them on a spec site it said the Canon has Autofocus while the two nikons don't. It may not be a motor I just assumed but canons site does list autofocus as a feature on the T3
I got the nikon d3100, looking back now I would have went with the d700 or d500 because the focus motors, and the lens are cheaper
Whats a d500? Did you mean D300? I think those may be out of the OP's price range.
Forgot to add the 0's haha I meant D5000 and D7000
...... looking back now I would have went with the d7000 or d5000 because the focus motors, and the lens are cheaper.
EDIT:
It's more expensive for the camera but lens that have the auto focus motor in them are a ton to buy, .....
Uh, that is not correct, and the quality of the optics in a lens also has to be considered.
Most of the current Nikon lenses that don't have a focus motor in them (designated AF) are last generation pro lenses, and are far from inexpensive, though there are a couple of exceptions like the AF 50 mm f/1.8D. Nikon makes many, inexpensive, entry-level AF-S lenses (with a focus motor).
Note that many of the lenses that have a focus motor also have the VR image stabilization system which also adds to the cost of a lens.
For example - The Nikon AF-S 35 mm f/1.8G has an MSRP of $199. The AF 35 mm f/2D is $390. The manual focus only Nikkor 35 mm f/1.4 is $1165.
if you like L lens, choose canon;if you like golden ring lens, choose Nikon; you like neither, choose pentax~
by the way, why not try pentax entry level DSLR?
um, it sounds like its getting too complicated already. believe it or not, all the entry level dslr's w/kit lens will do just fine for him considering it sounds like the op is just starting out with them anyway. not to mention those models retain their value quite well still and if he doesnt like one model you can always sell it and buy a different one. you add an inexpensive 50mm (which all brands make ) and you have a good start to begin learning the basics.
EDIT:
then there is the AF-S 35mm f/1.4G for $1,600 upwards.
I just picked up a DSLR myself (as a beginner) and would suggest shopping around. I bet you could find a T2i kit (18-55mm IS lens) within your budget. From there you can develop your photography by working on the basics and when you have a larger budget you can start upgrading your lenses. That's my plan anyway, I picked up a refurbished T2i kit for $550 (great sale through Canon direct!) and the 'nifty fifty' (50mm F/1.8) lens and I think its a great beginner set. It's easy to dream about getting L lenses and upgrading to a $1000+ body but keep in mind that you are a beginner still and have a very limited budget. Good luck!
