Settings from your second photo
f5.6
ISO 200
1/100sec
The aperture, f5.6, defines the amount of light being let into the camera by the lens and also affects the depth of field. For this kind of shot f5.6 is a solid choice, you might use f4 if you wanted a little less depth, even down to f3.2 I think would have been fine at this range; unless you wanted it all in focus (bird and water and background) then you'd want to use a smaller aperture (bigger f number).
ISO 200 isn't bad, a nice clean ISO
1/100sec - here is your problem in two fronts.
a) Handshake - the rule of thumb is 1/focal length of lens for the minimum shutter speed for a handheld shot to be sharp. That's a rough guideline and sometimes you'll find you have to use a faster shutter speed and sometimes you can get away with slower. So at least you want to be at 1/200sec at the 200mm end of your lens.
This type of blur appears as an even level of blur over the whole photo.
b) Motion blur of the subject - for a moving subject you've got to have a faster shutter speed to stop it blurring. 1/100sec is really too slow and risking it; for wildlife I'd say get up to 1/500sec if you can or faster.
This type of blur appears as blur around moving parts of the photo only
Note you can get, of course, both motion and handshake blur at the same time in a photo.
Thus based on the above you want to use a faster shutter speed so you've three options:
1) Use a wider aperture (smaller f number). Affects your depth of field; but also lets in more light and thus allows you to use a faster shutter speed
2) Raise the ISO. Yes a higher ISO means more noise; but well exposed photos at higher ISO are fine! You can fix noise in editing and pritning/display typically hides a lot too; but you can't fix motion blur*. So raising the ISO is important. For wildlife be prepared to use ISO 1600, 3200 or even higher!
3) A combination of a wider aperture and a higher ISO value.
*Practically speaking that is; in theory you can fix it but it will take so long its not worth it in most cases
