And if it is the print, how/where is the print being done.On the monitor, or on the print?
I believe it is properly calibrated since the color cast does not appear in all pictures, which makes it even more odd if you consider the fact that the workflow is always the same.
I don't see a color cast so downloaded your pictures and every tone has equal amounts r,g,b using the info window
I converted the mode to grey scale and they didn't change.
perhaps its a monitor issue.
Check your shadows and highlights in the design layout under split toning, maybe you have that turned on and didn't notice.
Even if you make it black and white you can still split tone it with a color, in your case purple
Just an idea.
Thanks a lot. I have checked the monitor and its settings - its defenitely calibrated. Maybe its my eyes, haha (could be)
