Critique
I can't remember the setting used it was awhile ago
EXIF Summary: 1/320s f/9.0 ISO100 55mm (35mm eq:82mm)
Noob question how did you do that? I would love to know because I keep a book and write my settings down now so I can learn from later.
Unless someone "wipes" the EXIF when posting or exporting, the EXIF stays with the file. It will save you some writing when making your notes. Just write down the name of the file and any comments about the shot (i.e.: subject's names, places (if you don't have GPS), weather, etc. The EXIF will be in the file unless you remove it.
(edit) just for grins and giggles, here is the sum total of what I was able to get (some readers are able to glean more info)
File name: 43533d1367255119-critique-dsc_0249.jpg
File size: 129297 bytes
Camera-Specific Properties:
Equipment Make: NIKON CORPORATION
Camera Model: NIKON D5100
Camera Software: Embettered by PicMonkey. http://www.picmonkey.com
Maximum Lens Aperture: f/5.7
Sensing Method: One-Chip Color Area
Color Filter Array Pattern: 750
Focal Length (35mm Equiv): 82 mm
Image-Specific Properties:
Horizontal Resolution: 240 dpi
Vertical Resolution: 240 dpi
Image Created: 2013:04:27 23:05:45
Exposure Time: 1/320 sec
F-Number: f/9.0
Exposure Program: Not Defined
ISO Speed Rating: 100
Lens Aperture: f/9.0
Exposure Bias: 0 EV
Metering Mode: Pattern
Light Source: Unknown
Flash: No Flash, Auto
Focal Length: 55.00 mm
Rendering: Normal
Exposure Mode: Auto
White Balance: Auto
Scene Capture Type: Standard
Gain Control: None
Contrast: Normal
Saturation: Normal
Sharpness: Normal
Subject Distance Range: Unknown
Other Properties:
Resolution Unit: i
Exif IFD Pointer: 216
Compression Scheme: JPEG Compression (Thumbnail)
Image Orientation: Top, Left-Hand
Horizontal Resolution: 72 dpi
Vertical Resolution: 72 dpi
Resolution Unit: i
Offset to JPEG SOI: 998
Bytes of JPEG Data: 6544
Chrominance Comp Positioning: Co-Sited
Exif Version: 2.30
Image Generated: 2012:10:16 03:20:01
Image Digitized: 2012:10:16 03:20:01
Shutter Speed: 1/320 sec
DateTimeOriginal Second Fraction: 30
DateTimeDigitized Second Fraction: 30
File Source: Digital Still Camera
Scene Type: Directly Photographed
Digital Zoom Ratio: 1
I'd definitely try and go back to the track if you can. Get closer, capture a moment, shoot low, get some motion blur, show his competition, etc. All these things will make your photograph more energetic and interesting. Cause you've shown you can document an event, but try to convey the emotions and possibly what it feels like to ride a dirt bike.
