Curious about your settings?
SuzukiGS750EZ
Connecticut
Hey guys. Curious about the settings you use MOST of the time for shooting wildlife. Can you post your settings and maybe the type of animals?
Birds
-RAW
-I customized my AF to only have single point or zone AF for faster switching
-Spot or Evaluative metering (depending on lighting)
-Auto White Balance
-AI Servo with back button focus
-High speed continuous
-Auto ISO
I think that's about it. I set up a custom shooting menu on C1 as well.
Edit: I as well shoot with the exposure comp on the set button and use the shutter adjust wheel to move it. Manual exposure mode and I have metering on the shutter button.
All wildlife
-RAW
-I use single point if the background is cluttered or all AF points for clear backgrounds like a blue sky. If I'm searching and don't currently have a subject I'm in all AF points.
-Manual
-Spot metering
-White Balance according to conditions
-AI Servo
-Auto ISO
Edit
-Exposure Comp on the Set+Shutter adjust.
mostly birds but some animals
-Raw
-one point AF
-spot metering
-i set the white balance
-Ai servo not using back button focus
-Continuous
-auto iso
-and it is in manual exposure
and the camera is a Cannon T5i
Mostly birds shutter priorities. F 6.5 unless light permit me to then Manuel F 8 shutter speed 640 tripod handheld at least 800 bird in flight 1600 unless light permit me to then 2000 spot metering. Auto ISO. White balance Auto. And I use a Nikon D7200 and a Sigma 150-600
Sent from my HTC Desire 626s using ThePhotoForum.com mobile app
All Wildlife,
- RAW
- Auto ISO
- 1/2000 Shutter Speed, although I could go to 1/1000 for stationary subjects.
- Aperture 6.3-8, normally 8.
- Aperture Priority mode.
- Auto WB
- Matrix Metering (should probably try out spot metering)
- Back button focusing using continuous focus.
- My D7100 is set to High Burst Mode.
For stills
-raw + jpg
- Aperture Priority
- Auto ISO (minimum shutter speed set to 1/250, I'll set it up to 1/1000 depending how twitchy the subject is but.)
- Auto WB
- ESP metering (Matrix)
- S-AF with back button focus (I prefer to use S-AF more than I do C-AF for stills.)
- C-AF without back button focus
- single point AF
For action/bifs
-raw + jpg
- Aperture Priority
- Auto ISO (minimum shutter speed set to 1/1250 for large birds and 1/2500 for small birds)
- Auto WB
- Centre weighted metering
- single point AF, 9-point or all points depending on situation
Birds
-RAW
-Auto White Balance
-Auto ISO
that's what I use
(if I remember to move the settings)
Wildlife in general, but mostly birds
Mostly Tv mode, shutter speed selected to match requirements; occasionally Manual
ISO as needed
Exposure comp as needed using "command" wheel
WB usually custom @ 5600K, occasionally "cloudy" or rarely Auto
Evaluative metering, occasionally partial, rarely spot
Center or center spot AF, occasionally expanded center. Rarely all-points if subject is on a clear, empty background like blue sky
AI Servo
High-speed continuous, 10fps
95% from tripod
