D80 DOF Lens
Dušan
Užice, Srbija
Can you recommend me few Nikon lenses compatibile with Nikon D80, but to have good DOF (depth of field) ? I need it to be under $120 or 100€ !
How much DOF do you need?
When I read "good DOF" I assumed you wanted it very deep, so you can take a closeup of a flower with the background mountains also in focus.
So it's shallow you want. I've not heard that ever called "good".
Here is the way to get a shallow DOF:
Use a longer focal length lens. Look for something at least 85mm.
Use a wider aperture. Look for a lens with a wide maximum aperture, say; f 1:1.8.
Separate the subject and the camera from the background. (back yourself away from the subject)
In your price range, I recommend the Nikkor 85mm 1:1.8, but you'll have to find a used one to fit your budget.
You're welcome.
You're welcome.
Anything else ? This one is 400€ used in my country :P
Go with graybeard's suggestion; post #5.
Since we don't know what is available in your area, it's hard to make recommendations. However, you've been given the basic information you need. For a very thin DOF, you need a lens with a large aperture (f/1.8 or better), and a longer focal length (50mm or larger). Used equipment is always (usually, and in North America) cheaper than new. Good luck.
That is the risk that you take buying from a place like eBay. You do have to do your homework on the seller, and see if there were any negative reports. As I understand it, if you use a payment service like PayPal, you have some recourse. There may be others as well that give some support to the buyer.
From eBay yes, but what if someone fools me ?
Can you get service from Amazon? I was surprised to see that in graybeards' link that Amazon lists this lens as NEW, and they have several examples. I assumed that since this lens is outdated that they would all be used, but no. As to finding used ones, there are 20 more examples of used ones available for even less money.
