Desert Pipeline
40737017
Sussex
Comments Welcome
Few comments.
I can't read the exif but the closer part of the pipe doesn't seem sharp enough. This is a tripod and small aperture kind of shot.
I suggest that the camera be a bit higher so that the geometry of the pipe's path be more obvious because the stuff that is close isstraight and semi-boring.
I think the overall composition is really fine, just a bit higher viewpoint would be good.
I guess you can't be out there at dawn or dusk to get that shadow off to one side; but that would be good.
If ever a picture would be better in b&w, it's this one.
Last, you don't get charged by the pixel, post large pictures.
I was using my monopod as the ground was so uneven.
I see what you mean about a higher angle but it seemed to obscure the bow in the pipe.
I thought 800 pixels was the forum limit???
How is this BW version:
EXIF:
Camera Make {0x010F} = FUJIFILM
Camera Model {0x0110} = FinePix HS20EXR
Picture Orientation {0x0112} = normal (1)
Last Modified Date/Time {0x0132} = 2014:05:15 23:23:52
Exposure Time (1 / Shutter Speed) {0x829A} = 10/8000 second ===> 1/800 second ===> 0.00125 second
Lens F-Number / F-Stop {0x829D} = 560/100 ===> ƒ/5.6
ISO Speed Ratings {0x8827} = 100
Original Date/Time {0x9003} = 2014:05:15 23:23:52
Shutter Speed Value (APEX) {0x9201} = 962/100
Shutter Speed (Exposure Time) = 1/786.88 second
Aperture Value (APEX) {0x9202} = 500/100
Aperture = ƒ/5.66
Exposure Bias (EV) {0x9204} = 0/100 ===> 0
Flash {0x9209} = Flash did not fire, compulsory flash mode
Focal Length {0x920A} = 4310/100 mm ===> 43.1 mm
Image Width {0xA002} = 4608 pixels
Image Height {0xA003} = 3456 pixels
I think you could move to the left a bit.
I was thinking of a conversion that would give more of an impression of the heat.
