Distortion correction in CS6 Question
Tinderbox (UK)
England
Hi
Is it possible to permanently enable distortion correction, as i have to enable it manually every time i load a raw file.
Thanks
John.
So nobody knows?
Well i found a way to apply lens correction ect, to every raw taken with a specific lens, see the link to the website below.
Optional: If Camera Raw managed to locate your lens profile (step 3), you can save that profile and any custom Correction Amount settings as your new default profile by choosing Save New Lens Profile Defaults from the Setup menu. In future Camera Raw editing sessions, if you choose Default from the Setup menu, and the current photo was taken with this lens, the saved profile and settings will be applied. (To restore the Adobe predefined settings for your chosen lens, from the Setup menu, choose Reset Lens Profile Defaults.)
Using the Lens Corrections tab | Using Camera Raw with Adobe Photoshop CC | Peachpit
John :)
Also be aware that you can batch apply RAW profiles. If, for instance, you want to do something different from your universal default, but still don't want to click it 100 times. Like, for instance, mass-correction of white balance on an entire shoot that had consistent lighting and manual mode.
