DOF
Weaving Wax
U.S.
Ok...I'm a little confused..
DOF is the distance in front of and beyond the subject that appears to be in focus. I know that the apeture will effect the DOF. The smaller the apeture the larger the DOF?
What is the difference between DOF and selective focusing? I get a little confused... Does focusing effect the DOF?
The larger the aperture (not greater, think size, not value) the less DOF the smaller the aperture, the greature the depth of field. As the aperture number decreases, the blades are opening up larger. An aperture of 1.4 if isnanely large, and has very little DOF, an aperture of 16 is very small and has large DOF. Take your 50mm 1.8 and put it on your camera body. Set it to aperture priority, look at the LCD and dial the aperture to 1.8, then ,looking into your lens from the front of your camera, adjust the aperture while holding the DOF preview button, this will show you that the aperture blades are gradually closing in as the number increases.
As for focusing, focusing is for getting an object to be as sharp as possible, I.E. in the very middle of your DOF. A lens at F/8 with your camera's AF system focused on the object, will yield that object in nearly razor sharp focus. It will, on a magnified scale, be the most focused out of anything in focus in your picture (will be the same for objects that are the same distance from the camera).
Thanks! That makes total sense now!
another thing that effects DOF is focal length and distance from subject, as I have been discovering with my latest toy.
It's a little hard to see on such a small image, but if you look at the bottom of the stem you can see where the focus is, and there is also a little sliver in focus on the sides of the apple directly across from the in focus stem. This spot is very very small even at this aperture, but you can make out the detail of some of the dust and the spots on the apple. Very very shallow. This is with aperture f/8 at 300mm about 38 inches away from the apple.
When you say 'selective focusing' do you mean the effect like the lensbabies achieve? if so, i would like to know the answer as well.
Almost. Actually, DOF extends beyond the plane of focus about twice as far as it does in front of it. Lens focal length and camera to subject distance also affect DOF, by the way. Aperture is just one of three elements to consider.
No...
I mean something like this:
Notice that the greenery in the front is the only thing in focus. But so is the fence in front of it..some of the greenery in the front is out of focus...but I got DOF and selective focusing confused. I now know that there are 3 different things that effect DOF.
When you say focal length do you mean like the mm on the lens (sorry don't know all the technical terms yet). Like my lens is a 50mm?
There is no such thing as "selective focusing". Every time you take a photo, you select a focus point. The amount of acceptable "in focus" part of an image is a factor of depth of field. How to control it has been discussed already. Just don't confuse it with a topic that doesn't exist.
Yes, a 50mm lens would have a focal length of 50mm.
Thanks. Someone else on here (can't remember whom) used the term "selective focusing". So I thought it was a real term.
Selective focusing makes sense, if you think of a lens baby, or any other tilt/shift type lens or camera. When you alter the lens angle to the film plane, you change the plane of focus, but that is not the same as depth of field, and does not apply to normal cameras/lenses.
So...
How does DOF preview work? I did use it and I did see the blades gradually close as the aperture got smaller and smaller... And at some of the smaller apertures (f/16) or so...I saw more of my image come into focus.. Is this correct or am I missing something...
Sorry for all the questions, but I think I'm starting to get it...
When you focus and compose your image, the aperture is always open to the max of the lens, even if your settings indicate f/22. When you press the depth of field preview button, it stops the lens down to the aperture in your settings, and thus gives you a preview of the dof. Unfortunately it also lets less light in, which makes it hard to see what you are getting.
Well you cannot see the blades closing through the view finder (or else all your images would have blades in them) you should just see it get darker, and less blurry, but I mean when looking into the lens from the front as you preview.
Yeah....thats what I meant. I cannot see the blades, but I can see the image getting darker.
Can this also be used to select the correct aperture (in Av) for the image?
Speaking of DoF, I know that it means "depth of field", but I've also heard it called "distance of focus". Now that I think about it, it could be both. Has anyone else heard 'distance of focus'?
