Don't laugh at me
I can't use flash with the ferrets. The light in the room will be fixed soon. My boyfriend screwed up the wiring so now he has to fix it hopefully tomorrow. In the meantime I'm just pushing buttons to see what they do and I feel like there's no logic to it.
Sent from my Pixel using Tapatalk
The front command wheel adjusts exposure parameters; which parameters depends on the exposure "Mode" the camera is set to. In P mode for example, moving that wheel adjusts the shutter speed AND the lens aperture, in lock-step. In Av mode, that wheel adjusts the aperture value (hence the mode name of 'Av'), while the camera meter selects the right shutter speed.
The camera manual ought to explain things additonally. I liked the ferret pics!
Have you tried using a smart phone? Sometimes smart phones tend to be even more effective especially for beginners who just wanna get a nice shot.
The reason I kept it at this setting is because my camera is an alien object. Lol I bought it in 2008. I only ever used auto. I turned that wheel once, got scared and turned it back. I probably used about 10 times throughout a year and then it never left the case after 2009. I've always wanted a simple point and shoot because all the options on this camera are useless to me because I don't know what it means. I am now learning though. There's no point in buying a new camera though because I don't aspire to be a photographer. I do want a waterproof sandproof dropproof one so my stepson can use it in the forest and pool and such
Cool, there's a reason I asked and depending on the answer it could have changed what I recomended next. A lot of learning photography is trial and error and we've all been there at somepoint unsure of settings so don't worry about it.
Can someone just come hold my hand?
ok, here is what I'd do:
Turn the big mode dial to M (manual mode, this will let you adjust shutter speed, aperture and ISO).
Then using the front command wheel in your picture turn it a couple of times and you should see the shutter speed change. Set it to 125.
Next press the ISO button and turn the wheel again, you should see the ISO change. Keep turning it up so the numbers increase, at the maximum it should go to auto (after 6400 the next one should be auto)
lastly press the Av button with your thumb and holding it down rotate the front command dial in your pic, you should see the aperture value change. Set it to f8.
You should then be ready to try some shots! let us know how you get on.
Thank you weepete. Still no light in the room but I did play around with my camera and set it to what you said. Just by that I am learning the options and what they do. I like m more than tv because I can control everything. I've tried reading the manual but it's very boring and I get distracted easily. I wish I knew about this forum years ago. I think I'm going to make a mini "studio" to get photos of the fur babies. This way I can have lighting and it will be small enough they won't be able to run away lol. That was my other issue. They don't listen to commands very well. One is actually throwing a fit in the litter box as I type this.
What weepete is suggesting is that you shoot in Manual exposure setting mode, at a shutter speed of 1/125 second, and at lens aperture setting of f/8, and using AUTO-ISO mode. The last part in weepete's suggestion is absolutely critical: that the camera be set to AUTOMATIC ISO Adjustment mode!!!
photography-shutter-speed-aperture-iso-cheat-sheet-chart-fotoblog-hamburg-daniel-peters-11.webp
This may help explain some terms and their use.
