I probably would not have chopped the building tops off.
What ISO and f stop are you using?
[h=2]Exif data[/h] [TABLE="width: 100%"]
[TR="class: lookatme"]
[TH]Camera[/TH]
[TD]
Sony DSLR-A580[/TD]
[/TR]
[TH]Exposure[/TH]
[TD]30[/TD]
[/TR]
[TH]Aperture[/TH]
[TD]f/14.0[/TD]
[/TR]
[TH]Focal Length[/TH]
[TD]50 mm[/TD]
[/TR]
[TR]
[TH]ISO Speed[/TH]
[TD]100[/TD]
[/TR]
[TR]
[TH]Exposure Bias[/TH]
[TD]0 EV[/TD]
[/TR]
[TR]
[TH]Flash[/TH]
[TD]Off, Did not fire[/TD]
[/TR]
[TR]
[TH]X-Resolution[/TH]
[TD]240 dpi[/TD]
[/TR]
[TR]
[TH]Y-Resolution[/TH]
[TD]240 dpi[/TD]
[/TR]
[TR]
[TH]Image Description[/TH]
[TD]SONY DSC[/TD]
[/TR]
[TR]
[TH]Orientation[/TH]
[TD]Horizontal (normal)[/TD]
[/TR]
[TR]
[TH]Software[/TH]
[TD]Adobe Photoshop CS4 Windows[/TD]
[/TR]
[TR]
[TH]Date and Time (Modified)[/TH]
[TD]2012:08:18 14:48:26[/TD]
[/TR]
[TR]
[TH]Exposure Program[/TH]
[TD]Aperture-priority AE[/TD]
[/TR]
[TR]
[TH]Date and Time (Original)[/TH]
[TD]2012:08:18 00:23:52-05:00[/TD]
[/TR]
[TR]
[TH]Date and Time (Digitized)[/TH]
[TD]2012:08:18 00:23:52[/TD]
[/TR]
[TR]
[TH]Brightness Value[/TH]
[TD]-3.75[/TD]
[/TR]
[TR]
[TH]Max Aperture Value[/TH]
[TD]2.8[/TD]
[/TR]
[TR]
[TH]Metering Mode[/TH]
[TD]Multi-segment[/TD]
[/TR]
[TR]
[TH]Light Source[/TH]
[TD]Unknown[/TD]
[/TR]
[TR]
[TH]Color Space[/TH]
[TD]Uncalibrated[/TD]
[/TR]
[TR]
[TH]Custom Rendered[/TH]
[TD]Normal[/TD]
[/TR]
[TR]
[TH]Exposure Mode[/TH]
[TD]Auto[/TD]
[/TR]
[TR]
[TH]White Balance[/TH]
[TD]Auto[/TD]
[/TR]
[TR]
[TH]Focal Length (35mm format)[/TH]
[TD]75 mm[/TD]
[/TR]
[TR]
[TH]Scene Capture Type[/TH]
[TD]Standard[/TD]
[/TR]
[TR]
[TH]Contrast[/TH]
[TD]High[/TD]
[/TR]
[TR]
[TH]Saturation[/TH]
[TD]High[/TD]
[/TR]
[TR]
[TH]Sharpness[/TH]
[TD]Hard[/TD]
[/TR]
[TR]
[TH]Compression[/TH]
[TD]JPEG (old-style)[/TD]
[/TR]
[TR]
[TH]Caption- Abstract[/TH]
[TD]SONY DSC[/TD]
[/TR]
[TR]
[TH]Date Created[/TH]
[TD]2012:08:18[/TD]
[/TR]
[TR]
[TH]Global Angle[/TH]
[TD]30[/TD]
[/TR]
[TR]
[TH]Global Altitude[/TH]
[TD]30[/TD]
[/TR]
[TR]
[TH]Photoshop Quality[/TH]
[TD]12[/TD]
[/TR]
[TR]
[TH]Photoshop Format[/TH]
[TD]Standard[/TD]
[/TR]
[TR]
[TH]Progressive Scans[/TH]
[TD]3 Scans[/TD]
[/TR]
[TR]
[TH]XMPToolkit[/TH]
[TD]Adobe XMP Core 4.2.2-c063 53.352624, 2008/07/30-18:12:18 [/TD]
[/TR]
[TR]
[TH]Format[/TH]
[TD]image/jpeg[/TD]
[/TR]
[TR]
[TH]Description[/TH]
[TD]SONY DSC[/TD]
[/TR]
[TR]
[TH]Creator Tool[/TH]
[TD]Adobe DNG Converter 6.6 (Windows)[/TD]
[/TR]
[TR]
[TH]Metadata Date[/TH]
[TD]2012:08:18 14:48:26-05:00[/TD]
[/TR]
[TR]
[TH]Rating[/TH]
[TD]0[/TD]
[/TR]
[TR]
[TH]Lens[/TH]
[TD]17-50mm F2.8[/TD]
[/TR]
[TR]
[TH]Lens ID[/TH]
[TD]128[/TD]
[/TR]
[TR]
[TH]Color Mode[/TH]
[TD]RGB[/TD]
[/TR]
[TR]
[TH]ICCProfile Name[/TH]
[TD]Adobe RGB (1998)[/TD]
[/TR]
[TR]
[TH]Original Document ID[/TH]
[TD]5932A993A688F48B7D8178C2BB07B325[/TD]
[/TR]
[TR]
[TH]History Action[/TH]
[TD]derived[/TD]
[/TR]
[TR]
[TH]History Parameters[/TH]
[TD]saved to new location[/TD]
[/TR]
[TR]
[TH]History Instance ID[/TH]
[TD]xmp.iid:76738EDB66E9E1118E6C89E220ECBC09[/TD]
[/TR]
[TR]
[TH]History When[/TH]
[TD]2012:08:18 14:03:52-05:00[/TD]
[/TR]
[TR]
[TH]History Software Agent[/TH]
[/TR]
[TR]
[TH]History Changed[/TH]
[TD]/[/TD]
[/TR]
[TR]
[TH]Derived From Original Document ID[/TH]
[/TR]
[TR]
[/TR]
[TR]
[TH]Color Transform[/TH]
[TD]YCbCr[/TD]
[/TR]
[TR]
[TH]Flash Return[/TH]
[TD]No return detection[/TD]
[/TR]
[TR]
[TH]Flash Mode[/TH]
[TD]Off[/TD]
[/TR]
[TR]
[TH]Flash Function[/TH]
[TD]False[/TD]
[/TR]
[TR]
[TH]Flash Red Eye Mode[/TH]
[TD]False[/TD]
[/TR]
[/TABLE]
