wackii
- Joined
- Mar 11, 2012
- Messages
- 375
- Reaction score
- 140
- Location
- Southern California
- Can others edit my Photos
- Photos NOT OK to edit
wackii, nice shots of a Snowy Egret. That they seem a little underexposed is a problem that we run up against when photographing a white bird on a darker background. Your old in-camera meter wants to try and make everything 18% grey, so the image ends up being underexposed. If you try these again, or something similar, then you might want to try using a -1/2 or -1/3 exposure compensation (EC), even maybe up to -2/3 compensation to allow for this significant contrast between the bird and the darker water. You might have to experiment a bit, because the actual EC will depend on the exact lighting conditions. The edited versions are much better.
Wackii... if you metered on the Egrets, you could have probably gone a 1/2 to a full stop of + EC (your Exif state you were spot metering).
I still find your edits a little underexposed. Laptops are hard to work with.. as any change in the display angle really changes what you will see.
I did a edit (just brightness) on my calibrated IPS panel... should be close. Did a curves adjustment with the white dropper on the brightest part of the bird...
Your edit is on top.. mine is on bottom
Wackii... if you metered on the Egrets, you could have probably gone a 1/2 to a full stop of + EC (your Exif states you were spot metering).
