Electrical Tape to Repair Bellows is an Abomination
One does not need to locate 'snooty vintage leather'. One only needs to find the proper craftsman who can easily emulate vintage leather when making a bellows.
Vintage hoi-piloi not necessary.
If it works, who cares? Cameras are meant to be used and not admired.
Restoration of an antique is one thing (though I agree, it'd be better to have bellows built), fixing a pinhole in a snap on a working camera is another. Sure, it'd be better to do it the "right way" but in a pinch I don't see much wrong with patching a pinhole with gaffers tape, duct tape, chewing gum, whatever. Eventually you'll replace the bellows anyway.
It depends on the camera. A $15K Deardorf you'll want to put in the money for a proper bellows restoration, and depending on your philosophy regarding original materials on such a project then you'll want to keep as much of the bellows as possible. Like I said, this is fine for restoring an antique, it's another for fixing a camera that you use.
It is correct that you do not need to locate "snooty vintage leather" as the proper craftsman would be responsible for such an endeavor. :lol:
If one wishes to emulate one could of course just use this.... https://www.amazon.com/Match-Patch-...=1474668533&sr=8-2&keywords=leather+duck+tape
Nothing like leather duct tape for the gentil crowd you know. :laugh2:
The other end of the stick would be my £1 folding Agfa. (Which may well have other issues as well as leaking bellows). Only a fool would spend loads of time & expensive materials sorting the bellows on that. If everything else is actually working, new bellows MIGHT make it worth £30, but only if your lucky with your buyers! Not worth the effort of a proper repair, but with a quick patch up it might be a fun toy to play with...
How can one exist with such a bohemian arritude.
This is how I once repaired the bellows on a Mamiya Six folder:
Mamiya
I don't know if the OP would approve but I think I preserved the appearance of the camera at least. I did use a small piece of tape in the process but it was gaffers tape which is a flexible, durable non-plastic product made of rubberized cloth and is not at all like most tapes. Only a small piece was applied to the inside of the bellows. I had to use something to cover the gaping hole. I tried leather at first but it did not work well for this purpose. I was not aware of mulberry paper before reading the OP's post and I will look into that. I believe silk is also used to repair bellows but I've never tried it.
Mamiya
This is awesome, I have a 1920s Kodak folder I would love to run a roll of film through but the bellows is cracked. Since I only paid $6 for the camera I figure I can risk destroying its value by using electrical tape to fix it.
You're also looking at the person who recently used liquid electrical tape on a Leica IIIa shutter to fix some pinholes and make it usable again. :allteeth:
