Yes, the battery door issue...with the Vivitar 285HV, Quantum Battery 1 (and perhaps others) uses a "dummy battery pack" at the end of the cord...the dummy battery pack is inserted into the body of the flash and the battery compartment door requires that you drill/cut/Dremel out a roughly pencil-diameter slot in the battery cover door, about 1 inch in length...that allows the cord to poke put from the flash, and at the same time, keeps the battery compartment door intact enough that the flash still works with 4x1.5 AA's in their special battery cassette. So...that's the way the Quantum Battery 1 powers a 285HV--with a dummy battery pack. The Quantum Turbo on the other hand, uses a plug-in cord, but does require that batteries also be inside the flash. The Turbo cords were dreadfully expensive--something like $65 back when a 2-bedroom apartment rented for $240 a month...I remember how much the cords for the Turbo stung!!!
Yeah, the recycle times...the Battery 1+, seen here, is only $224
QB1+ Quantum Battery 1 Plus
Note-it says "250 flashes",meaning manual full-power pops, but "1,000+" in AUTO-flash mode. I honestly think their specs are conservative. I've used my 20+ year old Battery 1 to shoot as many as 500 flash shots over the course of a high school basketball game, powering TWO 285's simultaneously in AUTO-Thyristor mode for a wider-aperture, which equates to 1,000 automatic flash pops, over roughly a 90 minute time span. If you would like to calculate a reasonable estimate, try loading your flash with new AA's, and using FULL-power manual, and see how many flashes a set of batteries gives until the recycle time drops below XX seconds, and then use that number as it relates to Quantum Instrument's specification of 250 full-power flashes. AUTO-flash is soooooo much more battery efficient than FUll-power manual flash that it's not even funny. The difference is like driving full-throttle in 2nd gear, versus driving at 2,200 RPM in 5th gear. LIke you said, " imagine it's going to be already faster than the standard battery setup, and that has only failed me once or twice as it is, so odds are pretty good that I wouldn't need anything faster."---YES, the basic Quantum Battery is significantly faster than standard batteries...when using a flash at wider apertures, like f/5.6, the recycle capacity is very quick on shoe-mount power level flash units, and even at FULL power manual, the Battery 1 gives faster recycling than ANY batteries I've ever used.
