FEELWORLD FPV-769A 7" HD FPV Monitor with 11.1V 4600mAh Rechargeable Battery Pack Kit
Link Delight Online Shop
Official Vendor
Supporting Vendor
If you are still looking for the ideal Monitor for FPV or aerophotography, FEELWORLD FPV-769A HD FPV Monitor is your best choice. Designed specially for FPV and outdoor operation purpose. The monitor has very bright image (adjustable) and very wide power supply range (6-12V).FPV-769A also has a very important feature for FPV users, it doesn't have "blue screen" problem when the signal gets weak. This feature makes you able to fly much further and never lose image. When VTX is not connected, it just show static, never turn blue or black.
Features
● The first ground stand HD monitor, designed specially for outdoor users, does not have “blue screen”, is your best choice FPV or aerophotography
● High resolution 800*480,contrast ratio 500:1 and brightness 400cd/ ㎡seizing much more clear world
● Multi color format support, enter the menu manually to select the same format as your cam.
● Analog composite video AV input, connect the aerial camera
● 16:9 aspect ratio, switch the display mode 16:9 and 4:3
● Connect with the camera, as a monitor or secondary monitor of aerial
● High brightness,contrast ratio&Dizzy-proof monitor with sun shade, to see clearly under sunshine.
● 1/4-20 thread hole is included in the bottom, easily to mount on the tripod.
Specifications:
Monitor
Panel Size: 7" widescreen
Brightness: 400 cd/㎡
LCD Type: TFT LCD
Resolution: 800 x 480
Aspect Ratio: 16:9 & 4:3
Contrast Ratio: 500:1
Light Source: LED Backlight
Surface Treatment: Anti-Glare
Viewing Angle: 70°/70°,50°/70° (L/R,U/D)
Inputs: Compostie 1 Video RCA Input, 1 Audio RCA Input
Input Voltage: DC 6-12V
Input Current: DC 0.5A-1.5A
Power Consumption: ≤8W Watts
Speaker: Built in, 1 Watt
Mount: "1/4"-20 Thread and VESA mounting socket (75mm)
Storage Temperature: -20°C to 70°C
Operating Temperature: -10°C to 60°C
Size: 182mm x 128mm x 30mm
Net weight: 360g
Battery Pack for Monitor
Battery type: Lithium Polymer Battery
Capacity: 4600mAh。
Output Voltage: 8.25V——12.6V
Max. Discharge Current: 4600Ma (1.0c)
Discharge Cut-off Voltage: 8.25V
Max. Charge Voltage: 12.6V
Max. Charge Current: 2300mA(0.5c)
Charging time: 8 hours (Standard); 2.8 hours (Quick)
Size: 160 x 64 x 38mm
Weight: 348g
This FPV-769A 7" HD FPV Monitor is sold $102.83. How do you think about it?
