I thought the 4/3 format was the aspect ratio of the capture?? Right?
I dunno...I really like the ability to have 24x36 as well as an in-camera 4:5 aspect ratio with the press of a button...I also like being able to shift to a 2x FOV crop at around 14 megapixels...it makes my small 45mm P-series Nikkor a semi-wide on "full frame", as well as a 90mm equivalent field of view "telephoto" lens. Nikon has been implementing multi-format capture options since way back in 2005 on its higher-end cameras...it's quite useful at times to be able to switch the capture's actual SIZE, or its proportional ratio (as in the 4:5 aspect ratio AKA 8x10 enlargement proportion!) with the press of a button and one, or two, clicks of the main control wheel. As MP counts go higher and higher, the heavier crop settings are actually becoming VERY capable. The D2x's 2.0x FOV setting was only 6.7 megapixels, and 12.2 was the full-field...now, with 36MP on the D800, I believe the crop is 16.7 megapixels in size...that's plenty of MP count for many,many uses!
