First Of The Series
Excellent work. I wouldn't touch it because I'd make it worse.
The challenges of the skin tones have been a problem, as was the matching between the man & woman as Joe pointed out. Went back and tried a different approach, using a targeted hue/saturation adjustment, frequency separation, and brushed color, which seems to work better. Yes or no?
I think this last revision is pretty good, except for the pool of light on her neck, which I do not think adds much.
Overall I like the look that you achieved
Thanks Derrel, I appreciate your comments. I see the light pool now that you mention it, I'll revisit that.
I agree with Derrel about the light on her neck.
I also agree that this last edit is better in that the light is not so bright.
You might try adding a bit of red to the highlights to give a slightly more healthy glow
orig on left +10 red on right
@The_Traveler I'd probably agree on bringing back a little red in the skin. Since these will be printed, once I get all of the shots matched, I'll do a soft proof to the lab profile and if needed do a final red channel levels adjustment layer with mask.
