fisheye in lightroom C&C
camera obscura
Dallas, TX
I just discovered that LR corrects barrel distortion with one click. That means I don't have to buy a wide angle lens or PT Lens. I still may buy a 24mm wide lens but I definitely don't need PT Lens (even though it's only $25). I just have to buy Light Room (I'm still using trial).
#1 Two Sides of a Building
#2 In An Almost Flat Field (that dot in the upper left is...)
The Moon
I realize #2 is still distorted. I'm working on that. So, as B&W's, how are they?
Not sure I understand what you're meaning here. What focal length were these taken at and what did you do to correct/distort them?
As far as B&W images go they lack contrast and a large part of the sky is blown out. As far as images in general go they are just not that interesting.
I'm confused too....shouldn't a wider lens cause more barrel distortion? As per b&w, they appear to grey for my taste.
I believe he is just pointing out that LR can fix the barrel distortion of his fisheye lens with one click. It does help the distortion a lot, but it won't fix it completely.
Yes, Blake has it right. Pardon me for being unclear. I just clicked on Enable Profile Corrections and LR automatically found my lens and un-fisheyed it lol.
The EXIF data says "Focal Length = 105/10 mm ===> 10.5 mm."
Here is the original of 2...
Thanks for the insight on them as B&W. I shall go back to the proverbial drawing board. :mrgreen:
