Flash outdoors, no gels, lesser of two evils?
So... get a new reflector; 3'x6' reflectors for only $13.50! As far as light placement goes, a lot is going depending on the ambient light at the location, but I would be more inclined to start around 30 degrees, given the size of your group.
Light will shoot through that?!? Awesome...I'll take three!
Is your reflector a true reflector or is it a diffusion panel with reflector covers? Either way, you can reverse fire your flash and have it bounce off your reflector making it a much larger/softer light source. An assistant would be helpful, not not necessarily necessary. For outside use, dump the dome idea as shown here.
The shower curtain is translucent. I've used it quite successfully many times. It's similar to my softbox diffusion panels.
Kundalini, NICE idea. My reflector has a blackout panel on the back so that might work really well!
A white sheet works well if you have enough flashes for coverage. These two were done with a white sheet hung from a low rafter with 4-5 flashes behind it to even out coverage and add power.
yeah, the one thing I'd worry most about the panel is the coverage/output.
I like kundalini's idea. You really only need 1 large light source and being dead center for a group shot isn't necessarily a bad thing.
you will quite often see the use of 1 HUGE light source directly behind the shooter; straight on.
like this:
