Don Kondra
- Joined
- Dec 11, 2007
- Messages
- 1,637
- Reaction score
- 904
- Location
- Saskatoon, Saskatchewan, Canada
- Can others edit my Photos
- Photos NOT OK to edit
Velbon tripod legs, ball head, pan/tilt head, 3 quick release plates and custom made Jobu Design lens plate/quick release plate to mount non collared lenses on a gimbal.
$430 value, asking a total of $200 US which includes paypal fees and insured shipping by Canada Post.
Velbon PH-157Q 3-Way Pan/Tilt Head with Quick-release platform system that incorporates some clever features such as a one-touch handle that allows locking of both pan and tilt movements with one twist..
The Velbon QHD-71Q Magnesium Quick Release Ball Socket Head is a heavy-duty ball head made from magnesium alloy with a built-in full-size quick release mechanism. By using magnesium construction a 20% weight reduction is achieved over traditional metals while still maintaining the same stability and quality. The one-touch locking knob controls both the panning and ball movement at the same time. There are two bubble levels on the quick release base for more precise leveling in Portrait and Landscape mode. Camera mounting screw is latterly adjustable for custom camera positioning
The load capacity is up to 13.2 lbs.
Velbon Sherpa 550R with slanting tooth geared elevator for smooth adjustment and a friction adjuster that enables tension adjustment of centre-column elevator.
Features:
◦Maximum Height: 61"
◦Minimum Height: 10 3/4"
◦Folded Height: 24 3/4"
◦Weight: 4.7 #
◦Diameter of Leg: 26mm
◦Leg Sections: 3
◦Maximum Load: 8.8 #
The Jobu Design NX1 Surefoot Lensplate (3.5") is designed to safely mount and secure most small telephoto lenses. It features double safety-stops and a double-dovetail profile and is compatible with all other North American Arca-Swiss-style lens plates. It also has a built-in anti-twist flange to prevent your lens from unscrewing during use.
Clicking on the image should take you to an album with additional images..
Cheers, Don
Features:
◦Weight: 4.7 #
◦Leg Sections: 3
Cheers, Don
