Gamma Slider?
unpopular
Montana
Just a quick question: do most RAW processors have a gamma slider?
None I've used have one, as far as I can remember.
It appears that the Nikon one does, just below the curves there is a levels adjustment. I realized that the middle slider in Levels is actually Gamma. Haven't used levels ever since a histogram appeared in curves.
Most of them probably have something similar, or a combination of sliders that can give a similar result, but none I've seen call it gamma. I've only seen gamma sliders in film scanning software.
The middle slider on levels - is that midrange tones? In the software I've used, that didn't really behave like the gamma slider I'm used to... (which is not really good or bad, just different.)
well. in my editing software the slider is called 'gamma' and scales from 0.1 to 10, which sure sounds like a gamma exponent. as I am sure you know, gamma is a *very* specific operation.
Sounds like the gamma slider I'm familiar with - I've just never seen it on a RAW processor before.
hmm. if I don't get an definitive answer, i'll d/l the Nikon and Canon software and some raw files from dpreview.
I know that the softwrae I use (raw photo processor) has one, and that C1 has one.
Very akin to the blacks slider in ACR/LR. PS has a gamma slider if you are adjusting the exposure in an exposure layer. You get more over-saturation of the colors with gamma there. Blacks will make your colors pop, but the over-saturation doesn't happen, it just starts turning black.
Gamma can be very useful in an exceptionally flat and colorless image. You can bring back a lot with the saturation, vibrance and blacks, but gamma is definitely easier to use in that case.
But more importantly why do you ask?
There is a standard gamma curve applied to the linear raw sensor data. The gamma curve can be approximated in curves, and every raw converter already has a myriad of other contrast / tonal adjustment tools.
Sorry guys for the delay!
I'm working on a unified exposure system for digital, similar to/based around the zone system that actually does what the zone system does, rather than a pretentious way to explain exposure compensation that sounds impressive.
I need a standard image transformation, such as a gamma function that will be similar across all image editors.
As I am learning more about the math involved here, I think I can just use curves after all. Thanks all for your input! :D
