Gettin new glass
McQueen278
Ann Arbor, MI.
I'm picking up a 17-40mm f/4L and a 70-200mm f/2.8 IS USM. Who has these and how do you like them? I understand that the 17-40 is very sharp and has good contrast on the wide end, has anyone ever found it truly lacking at the narrow end? How is the 70-200 at 2.8, how much better is it at 4 than 2.8? How happy have you been overall with either lens? Any problems with them ever?
Nobody has or has used either of these lenses?
Most lenses don't perform their sharpest when fully open - stopped down once or twice they tend to show sharper results.
I am in a similar boat with refrence to nearly owning the 70-200m
Lost Prophet uses the 70-200mm f2.8 IS L USM if you are after some shots:
here are some I found where he also uses the lens with the teleconverters as well - to good effect (which shows the overall high quality of the lens)
http://thephotoforum.com/forum/showthread.php?t=103319
Overall I think you will be happy with the results of L lenses - have fun with your first L glass!
