Hand cut dovetail kit
Don Kondra
Saskatoon, Saskatchewan, Canada
Current project includes hand cutting dovetails in six drawers for a ladies dresser.
In anticipation of this I've just received a coping saw from Knew Concepts and a marking gauge from Lie Nielsen, an upgrade if you will from more traditional tools :sexywink:
Everything you need to hand cut dovetails..
The lighting set up...
Cheers, Don
Sometimes wish I had the time to get back into woodworking...
This is just a matter of taste and I didn't always use this technique but here is one set up I used sometimes when I didn't want as many shadows as you have here. I would set up the objects on top of a piece of glass with a fairly thin piece of paper/material on top of the glass and blast light from below.
Thanks for that, I'm sure others may find it helpful.
I find I use that technique less and less as I come to appreciate the added dimension that shadows lends to objects.
Cheers, Don
