HELP?? Underexposed and noisy :(
tmjjk
Cleveland
This is the original
2. Crappy Edit
I would like to know how to avoid this in the future. Any help would be greatly appreciated. This was shot at iso 200 50mm f3.5 1/160
It's not that noisy! But you could shoot with a larger aperture or lower the shutterspeed and use a tripod or something like that. Also, you could buy yourself a cheap light reflector to use as a fill light for these kind of pictures.
So.... more light=less noise? Sorry still learning.
Yes, more light = less higher ISO = less noise. But then again, if you shoot an underexposed picture with low iso and therefore have to bump up the exposure dramatically in photoshop, you'll end up with a noisy picture.
I think it's an adorable picture.. I played with it a little. I'm a beginner as well, but I like to play. :)
My recommendation would be to learn how and when to use fill flash, and how the three different metering modes work, the pros and cons of each, and when to use them. Either or both could have prevented that underexposure.
Tami, your edit looks great!
All of the above, and also put them in a better spot, one where their hands are not cut off by the grass and the background is not brighter than they are.
This...But the pictures isn't lost, I believe TamiAZ just proved it salvageable
Thank you to all... going to do some reading on fill flash and metering modes :)
I have this Walmart.com: Canon Sunpak DF3000 Flash: Digital Cameras
Would this work as a fill flash... I know it is very inexpensive and may be garbage, but I thought I would give it a try as I have never experimented with flash
