Newbie question.....
What accounts for the amazing vivid colors I see with photos taken by folks that know what they are doing. My guess is there are many variables but how much of it is post processing and in what way ? My stuff always seems a little bland.
My stuff -
Denny Noll
Any input would be appreciated.
Reading through this thread I'm puzzled why nobody has suggested the obvious:
If you want to know how to edit colour then learn about colour.
Colour is not a property of light, colour is how the human eye differentiates between wavelengths. It is also worth noting that the human eye has not evolved to see in absolutes but to give us the best chance of survival. We see by recognising slight differences, in fact your eye is tuned to exaggerate these.
The upshot of this is that
colour is perceptive, not absolute.
We live in a world of subtractive colour, we see a world of subtractive colour. We do not see in RGB and RGB does not explain colour or have anything to do with how editing programs handle colour. All RGB explains is how an additive system such as a computer screen displays colour and tricks the eye into seeing (almost) the full spectrum by using only red, green and blue.
It is important to realise the above, very important if you're to understand how to lift your images.
As we live and see in a world of subtractive colour, and colour is perceptive all editing programs are based on perceptive colour theory which is the standard subtractive colour model.
I will try to demonstrate.
There is no separation between colour and luminosity, this is just the construct of what I like to call the "narrative of absolutes", a logical framework many apply because they find it easier to understand. Colour has three properties in the standard colour theory, hue, saturation and luminosity. Contrast exists between all of them, it is not a property of luminosity alone. Colour (hue) affects luminosity and luminosity affects colour (hue).
Here is a yellow against blue, the yellow is slightly desaturated and at 100% luminosity and the blue is more saturated and at 68% luminosity. Note the apparent contrast:
Here is the same yellow against green. The green is exactly the same saturation and luminosity as the blue. Do you see more or less contrast between the two? Remember all I've changed is the hue:
So I can change the contrast just by changing the hue, leaving saturation and luminosity the same. It proves that there is a visual contrast between hues, or colours.
Here is the first image again but this time I've reversed the luminosity, the yellow is 68% luminosity and the blue is at 100%:
So where did the contrast go? Different colours have different visual luminosities and if you try to reverse this contrast and colour will disappear. As you see above compared to the first image, exactly the same hue and saturation but I've simply reversed the luminosity and look what happens to both the impression of colour and contrast. (NB. This is a similar effect to excessive tone mapping where the natural luminosity of colour is reversed. The impression of both colour and contrast is greatly reduced. It is also important to understand that all cameras and editing programs work on a
perceptual model, that is to say that they convert or change the luminosity and saturation of colours differently in line with human perception. it is not an absolute model but one based on perceptive colour theory).
My choices of colours here are no accident, I deliberately chose colours that show the greatest variations in combinations and when reversed because I understand colour theory. Look at many tone-mapped images and you will see the colour more similar to the bottom image, look at images where the colour appears like the first one and you will see more vivid colour.
It is important to note that the saturation of the first and third images is exactly the same for the colours, it is not that which makes colours pop, it is quite simply:
Understanding colour.
Contrast changes saturation, it's as simple as that. In line with subtractive colour theory, adding white, (all the colours of the rainbow), de-saturates colour. This both changes the colour and your perception of it because you've altered the luminosity. What the editing programs do is to increase saturation in line with perception as you increase contrast. The idea is to make the colours appear as stable as they can. It is not that you perceive the colours to be more saturated because of the increase in contrast but the exact reverse, you see the colours as less saturated, (
in the editing program. In line with perception and the real world increased contrast, i.e. a sunny day, produces a greater impression of colour. It is just difficult for a photo to show because the reduced contrast of a screen or print either pushes the colours towards white and black or reduces their contrast and therefore your reduces the impression of colour. Subdued colour can look better in print simply because it suits the contrast range of the paper better.), so the editing program makes a very real increase in saturation to compensate. This increase is in line with perception and is not linear but varies dependant upon hue, different colours behave differently perceptually as you see in the third image. Light yellow against deep blue is visual far different from a deep yellow against a bright blue. If you want to see a much lighter blue against a darker yellow here it is:
Now you would think, with a conventional "narrative of absolutes" that increasing the difference in luminosity between the two colours should increase the contrast. But the visual effect is the complete opposite. There is no getting away from the fact that we perceive yellow as a light colour and blue as a dark one, and no denying that in terms of colour and contrast the first image is far more vivid even though it has less difference in luminosity than the fourth image, (52%/100%).
If you want proof that editing programs edit colour based on the subtractive colour model the see what happens when I overlay the blue at 50% opacity over the bright yellow. If it works in line with an additive colour theory then the combination of the light blue and light yellow should produce a colour that is the combination of the light combined. Subtractive theory though, dictates that only the common wavelengths are reflected and all others as absorbed, so the result will be a darker grey. See for yourselves:
The editing program has not combined the light of the two colours emitting from the screen, instead it has done a rather complex calculation based on a perceptive model and worked out what colour you would expect to see with a real human eye in a subtractive model such as the real world and displayed that.
Vivid colour is not saturation, vivid colour is colour edited by someone who understands colour.
Though it is not essential to fully understand why, I am hoping that I've shown enough to allow you to question your understanding. I hope this helps. ;-)
