high key high
JohnMF
Hi, can anybody share some of the techniques they use in PS to create high key images. Every time i try it they always look wrong. Usually flat and blown out
Thanks
What's high key mean in this situation?
Im guessing by you saying "High-Key" you mean a light image (Mainly built up of whites and high end white mid-tones)?
For a high key black and white image, I would convert to B&W using the channel mixer. Duplicate your channel mixer adjustment layer, and set its blend mode to "soft light", or for even higher key, "overlay". Your end result should be a very high contrast image, with very bright white skin tones.
You can do the same for color, just do one channel mixer, and set its blend mode to soft light or overlay.
Sorry, yes, that's what i meant
Thanks i will try out your technique Matt
Generally it's best to shoot a photo with the intent for it to be high-key -- that is, to expose it so you end up with mostly lightness in the image. It probably isn't as good to try to adjust the exposure later in photoshop. That might be why you're having trouble.
