According to the metadata on the image you're using a Canon EOS 7D Mark II, which according to what I read, supports HSS. You'll need to go into the menus and set flash to HSS and use a compatible flash that also supports High Speed Sync (HSS). I'm sorry I don't use Canon so I'm not overly familiar with it. Surprisingly there isn't a whole lot of information out there on the Mark II and HSS.
I've used HSS frequently on my Pentax K1MII, with a Pentax speedlight. I can tell you that my experience with it is-
1. It can be finicky especially if using a 3rd party speedlight. Just because a 3rd party speedlight "says" it's compatible with your camera doesn't mean it will be.
2. If you need to move the flash off camera not all synch cords will work with all cameras. Again, I had to search through several "so called compatible" cords before I found one that actually was.
3. You have to use one of the program modes with HSS, like Aperture Priority or Shutter Priority.
This was shot HSS f/5.6 at 1/4000 with speedlight off cameras
cotton fields 202220220923_5737.jpg by
William Raber, on Flickr
Another HSS f/5.6, at 1/2500 with speedlight on camera.
December 202020201229_3848.jpg by
HSS to me gives a pop that can't be duplicated with ambient or conventional strobe lighting.
