OK, I'm sorry if this constitutes me derailing the thread, its not my intent.
Take a look at the following picture.
That was my setup for both of the pictures in the previous post. Basically the concept behind high speed photography is pretty simple... you want to isolate the shortest period of time possible. Even the fastest shutter speeds on normal DSLR cameras is much too slow.
That's where the flash and audio trigger comes into play.
Here is the total process from start to finish for me to set up one of these shots.
1. Set up my materials... Camera, flash, box, subject and shutter remote... all near the ambient light source so I can shut it of completely.
2. Get me exposure. Since this is a completely dark room, and my shutter speed will be several seconds, the only things contributing to the exposure are the aperture, flash power, and ISO. I try to always keep my ISO at 100, which normally isn't a problem with these shots. The flash is the shortest at it's weakest setting, so my exposure usually ends up beint ISO 100, somewhere in the f/3 range and the SB-600 at 1/64 power. The exposure is easy to get. get the subject in focus, turn the lights off, open the shutter (bulb setting so you need to physicall open and close the shutter) flash the strobe, close the shutter, check your results and adjust as necessary.
3. once the exposure is set, then comes the fun part. For you, you would attach the audio trigger to your flash. Keep in mind that the SB-600 doesn't have a PC sync, so you will need a hotshoe adapter. The Flash is NOT attached to the camera. Now clap your hands. Notice how the flash goes off? Groovie.
4. get ready, and take a deep breath.
5. now, with your shutter remote in hand, and your subject in focus (lets use a balloon as an example), do these things in the following order.......
1. shut off the ambient light. All of it.
2. open the shutter with the remote on bulb setting (remember, that you could sit here for an hour with the shutter open, and unless the flash goes off, no image will be recorded....)
3. pop the balloon (at this time, when the balloon pops, the audio trigger will hear it, and activate the flash, the flash...about 1/10,000 sec in duration... your only light source.... will produce the image of the balloon in mid pop)
4. close the shutter
5. turn the lights back on
6. downoad the image to your computer, and marvel at just how damn cool it is.
Please let me know if I can clarify further.
