How can you make sure it is focused on the eyes?
If you are doing portraits you want to be at f/5.6 - 7.1 for simplicity
You have to learn about your focusing modes on your camera. See my post above
To focus specifically on an eye you have to be in a Single Focus Point mode and thus focus on ONE eye. You CANNOT be in an Auto mode because you are then letting the camera do the thinking.
This does not mean that both eye will be in focus. This is dependent upon your Depth of Field which is based on your distance and aperture .. see the DOF calculators about that.
You might want to tell us what camera you have .. then someone can give you more info on your focusing modes and how to change them.
Keep in mind. just because you have a lens capable of f/1.8 does not mean f/1.8 is the best setting for what you are attempting to do. At some point you may have to ADD more light if you are taking a picture of people
- You can raise the ISO which makes the camera more light sensitive, but may introduce noise.
- You can lower the shutter which may introduce movement if too low. But generally try to stay above 1/120
- you can use a lower f/1.8 which allows more light in but gives you a shallow depth of field (the problem here).
- or you add light - brighter room or flash
Generally. With the proper DOF (aperture) selected, the proper shutter speed. Then a good ISO that doesn't introduce too much noise. If it's still dark then you have to add Light somehow.
In the photo you have alot of light coming in on the side, which is a different problem. You could use a reflector to reflect the incoming light back onto the front of the subjects, adding more light.
But you still need to know how to properly select a focus point for proper DOF
