How is this gear for a $2500 budget?
dpbofg
CA
I really like your choices, however I would strongly suggest into getting a flash and you will be all set :)
I'd pass on the 50mm 1.4 and get the 580 EX-II flash instead, even though it means a bit more cash spent.
I would ditch the 18-135mm, 50mm and the bag and get 24-105mm f/4 L instead.
I don't know crap about anything, but I would also suggest maybe going with 4 4gb or 2 8gb cards instead of 1 16gb.
Better question would be, what are tour plans/what do you shoot? You probably won't even be able to use the benefits of an expensive body like that. You could get a lower model body and save a LOT of money and spend it on quality glass (cause the lens is WAY more important than the body)
Good glass can make better images before an expensive body will!
I'm a Nikon guy so I don't know what to recommend, but spend about a grand on the body and don't opt for a kit lens...they're junk usually. Then get some nice primes ad a 2.8 zoom and you'll be better off!
Just my .2¢ ;)
Sent from Erics iPhone www.ericporado.com
Pop-up flashes should be avoided is possible and of-course if the pop up flash is the last resource, then by all means use it but a designated flash is much much better.
The 24-105 f4 L is a beautiful lens and the price is quite nice also. the constant aperture of f4 is awesome not to mention better built, better glass and faster AF if I am not mistaken. I would definitely drop the lens you got there and get the 24-105 f4 and a flash if you can swing it. Also good glass retains value and can be used for many years to come if its well taken care of.
The package u listed will serve you quite well for some time so nothing to worry about there but consider getting a flash also.
Online shopping FTW...no tax
Now thats not always true. Plus online you have shipping costs usually.
Well the shipping will not be as expensive as taxes for many places... for example last week I bought a Blackrapid Sport-strap for 69 from US and had it shipped to Canada. With shipping and duty it was still 20$ cheaper then purchasing it from a Canadian store for 99.99 +12% HST
Now if I was in the States it would have been 19$ cheaper then what I got it for shipped :(
My suggestion is to seriously consider buying used. Check fredmiranda.com and POTN for some good prices on used lenses and bodies. Look into refurbished as well.
As an example the 24-105L should go for about $825-900 used, and the 50 1.4 should go for about $325-350 used.
You may find that the cost savings will allow you to get farther with your 2500 budget.
Drop the 50mm and get a flash. Also like many have said, buy used. You'll save a few hundred dollars to spend elsewhere.
