How to convert size, when i have MPix and resolution?
raku
Hello all, I have one question. I need to know how to convert the sizes this way:
Let's say, that I have a picture, with that resolution: 2870 x 2777 (7.97MPix).
How can I know what width and height (in pixels) it will have on 1 Mpix, or 2.5 MPix? Has somebody an idea?
Thanks in advance,
raku
2870 X . 2777X = 1 e 6
Solve X
2870 X . 2777X = 2.5 e 6
Solve X
Then just use multiply 2870 by X
Solve X
Solve X
I doubt it's that simple. Image files contain more than just pixel data.
I tried the pixel count idea, and reduced a 91.2 kB image 50%. The result was a 76.9 kB file.
OP never mentioned about file size. All OP said was Megapixel. It would have been simpler if OP kept the crop ratio to 2:3. You confused MPix (mega pixel i guess) to MB sparky.
the size of a file is dependent on the original dimensions in pixels and, if any, the amount of compression with which it is saved.
So you can save a file with greater compression and the filesize will be smaller even though the pixel dimension stays the same.
Guys, I need only the new size in pixels. I have the big size, as mentioned in first post. I have it's width x height and megapixels. I have also Megapixels of the "new" size, which I want to get the size (width x height). I don't care about the quality, cause I don't provide the photos : ). I have to only know the exact size. So, do you know the formula?
1 MP image size = (1,000,000 / Original MP image size) * Original MP image size
@480sparky
IMO, it still says me nothing. How should I use it to achieve my goal?
@480sparky
You want a formula, and you get a formula. Now you can't figure it out?
Replace the Original MP number you have and insert it into the forumula. Then calculate for the result.
Step by step instructions:
Multiply your Original image pixel dimension together (width by height).
Divide 1,000,000 by that number.
Multiply your Original image pixel dimensions by the result.
